Ir para o conteúdo principal
Eclipse 180BL LCD Screen Cover Replacement
O que você precisa
  1. Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: passo 1, imagem 1 %32 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: passo 1, imagem 2 %32 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: passo 1, imagem 3 %32
    • To start, remove the two screws located at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair ToolKit.
    • Both Screws are 1/8 inch in length.
    • Remove the case, and with the Spudger, apply force to the USB port to remove the inner component.
    • Be careful, as releasing the tension will cause all parts to become loose and separate.
  2. Eclipse 180BL LCD Screen Cover Replacement: passo 2, imagem 1 %32 Eclipse 180BL LCD Screen Cover Replacement: passo 2, imagem 2 %32 Eclipse 180BL LCD Screen Cover Replacement: passo 2, imagem 3 %32
    • The LCD screen cover is placed into its slot after all the inner components are replaced.
    • Get the new screen cover, and carefully place in alignment with the outer shell.
    • Be sure that the screen fits perfectly, as dust getting in the screen will cause pixels to die.
Conclusão
Thomas Schwarz
Membro desde: 09/07/15
499 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 542
