Introdução
Following these easy steps will allow you to successfully replace the battery in the device.
O que você precisa
Remove the two screws located on the bottom of the device with a phillips head screw driver.
The bottom cap will come off to reveal the inside main component.
3 outras pessoas executaram este guia.
