Ir para o conteúdo principal
Echo Dot 3 Mic/LEDs/Button Replacement
O que você precisa
  1. Echo Dot 3 Mic/LEDs/Button Replacement, Outer Shell: passo 1, imagem 1 %32 Echo Dot 3 Mic/LEDs/Button Replacement, Outer Shell: passo 1, imagem 2 %32
    • Turn your Dot around, so that the Barcode is facing up, and the buttons down.
  2. Echo Dot 3 Mic/LEDs/Button Replacement, Bottom "Lid": passo 2, imagem 1 %32 Echo Dot 3 Mic/LEDs/Button Replacement, Bottom "Lid": passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    Spudger
    $3.99
    • Using a Spudger remove the Lid.
    • There's Adhesive under the lid, so the best way to get it off, is to go all the way around with the Spudger
  3. Echo Dot 3 Mic/LEDs/Button Replacement, Shell unscrewing: passo 3, imagem 1 %32 Echo Dot 3 Mic/LEDs/Button Replacement, Shell unscrewing: passo 3, imagem 2 %32 Echo Dot 3 Mic/LEDs/Button Replacement, Shell unscrewing: passo 3, imagem 3 %32
    TR6 Torx Security Screwdriver
    $5.99
    • Unscrew the 4 T6 Torx screws using the Right Screwdriver
    • After unscrewing, you can slowly lift the shell, and you'll be greeted by the insides of the Dot!
  4. Echo Dot 3 Mic/LEDs/Button Replacement, Insides: passo 4, imagem 1 %32 Echo Dot 3 Mic/LEDs/Button Replacement, Insides: passo 4, imagem 2 %32 Echo Dot 3 Mic/LEDs/Button Replacement, Insides: passo 4, imagem 3 %32
    • Unscrew the 3 T6 Torx screws,
    • and lift the flex cable connector.
    • After that, very carefully remove the PCB/Power supply (no idea).
  5. Echo Dot 3 Mic/LEDs/Button Replacement, Middle part: passo 5, imagem 1 %32 Echo Dot 3 Mic/LEDs/Button Replacement, Middle part: passo 5, imagem 2 %32
    • Remove the 4 T6 Torx screws (2 different lengths!)
    • Slowly Remove the Middle part
    • Be very careful while removing the middle part, so that you don't damage the cable!
  6. Echo Dot 3 Mic/LEDs/Button Replacement, Top part: passo 6, imagem 1 %32 Echo Dot 3 Mic/LEDs/Button Replacement, Top part: passo 6, imagem 2 %32 Echo Dot 3 Mic/LEDs/Button Replacement, Top part: passo 6, imagem 3 %32
    • Remove the 4 T6 Torx screws,
    • and lift the plastic to remove it.
  7. Echo Dot 3 Mic/LEDs/Button Replacement, Motherboard: passo 7, imagem 1 %32 Echo Dot 3 Mic/LEDs/Button Replacement, Motherboard: passo 7, imagem 2 %32 Echo Dot 3 Mic/LEDs/Button Replacement, Motherboard: passo 7, imagem 3 %32
    • Simply flip the device to separate the:
    • Motherboard and
    • Buttons from each other.
Conclusão
Congrats! To put together your Echo Dot, simply follow the instructions backward! Have a nice day!
ashlynn
Membro desde: 05/10/22
190 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 36
Ao todo: 815
