Ir para o conteúdo principal
Echo Chain Saw CS590 2019 Woodruff Key Replacement
O que você precisa
  1. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Turn off the chainsaw: passo 1, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Turn off the chainsaw: passo 1, imagem 2 %32
    • Make sure you have the ignition switch turned off before starting your repair.
    • The chainsaw should be cool to the touch before continuing.
    Pergunte ao FixBot
    Comentar
  2. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Loosen the air filter cover: passo 2, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Loosen the air filter cover: passo 2, imagem 2 %32
    • Use your fingers to loosen the air filter cover knob.
    Pergunte ao FixBot
    Comentar
  3. Echo Chain Saw CS590 2019 Woodruff Key Replacement: passo 3, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement: passo 3, imagem 2 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement: passo 3, imagem 3 %32
    • Remove the air filter cover.
    Pergunte ao FixBot
    Comentar
  4. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Disconnect the spark plug: passo 4, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Disconnect the spark plug: passo 4, imagem 2 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Disconnect the spark plug: passo 4, imagem 3 %32
    • Use your fingers to pull up and disconnect the spark plug boot.
    Pergunte ao FixBot
    Comentar
  5. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the air filter: passo 5, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the air filter: passo 5, imagem 2 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the air filter: passo 5, imagem 3 %32
    • To minimize debris entering the intake, pull the choke shut before continuing.
    • During reassembly, clean the air filter with compressed air or with light brushing before reinstalling it.
    Pergunte ao FixBot
    Comentar
  6. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Unfasten the front handle: passo 6, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Unfasten the front handle: passo 6, imagem 2 %32
    • Use a T25 Torx screwdriver to remove the five screws securing the front handle to the bottom and right side of the device:
    • Four 24 mm-long screws
    • One 25 mm-long screw
    Pergunte ao FixBot
    Comentar
  7. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the front handle: passo 7, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the front handle: passo 7, imagem 2 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the front handle: passo 7, imagem 3 %32
    • Pull the handle toward the rear of the device to remove it.
    Pergunte ao FixBot
    Comentar
  8. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the sprocket guard: passo 8, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the sprocket guard: passo 8, imagem 2 %32
    • Use a 13 mm wrench to remove the two nuts securing the sprocket guard.
    Pergunte ao FixBot
    Comentar
  9. Echo Chain Saw CS590 2019 Woodruff Key Replacement: passo 9, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement: passo 9, imagem 2 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement: passo 9, imagem 3 %32
    • Remove the sprocket guard.
    Pergunte ao FixBot
    Comentar
  10. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the guide bar: passo 10, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the guide bar: passo 10, imagem 2 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the guide bar: passo 10, imagem 3 %32
    • Push the guide bar towards the back of the device to create slack in the saw chain.
    • Pull the guide bar away from the device to separate the saw chain from the clutch drum.
    • Remove the guide bar.
    Pergunte ao FixBot
    Comentar
  11. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Unfasten the front hand guard: passo 11, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Unfasten the front hand guard: passo 11, imagem 2 %32
    • Make sure the front hand guard is in the unlocked position before continuing.
    • Use a T25 Torx screwdriver to remove the two 20 mm screws securing the front hand guard.
    Pergunte ao FixBot
    Comentar
  12. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the front hand guard: passo 12, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the front hand guard: passo 12, imagem 2 %32
    • Pull the front hand guard toward the rear of the device to remove it.
    Pergunte ao FixBot
    Comentar
  13. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the engine cover: passo 13, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the engine cover: passo 13, imagem 2 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the engine cover: passo 13, imagem 3 %32
    • Pull the engine cover straight off the device to remove it.
    Pergunte ao FixBot
    Comentar
  14. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Unfasten the starter case: passo 14, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Unfasten the starter case: passo 14, imagem 2 %32
    • Use a T25 Torx screwdriver to remove the four 24 mm screws securing the starter case.
    Pergunte ao FixBot
    Comentar
  15. Echo Chain Saw CS590 2019 Woodruff Key Replacement: passo 15, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement: passo 15, imagem 2 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement: passo 15, imagem 3 %32
    • Remove the starter case.
    Pergunte ao FixBot
    Comentar
  16. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Reposition the spark plug cable: passo 16, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Reposition the spark plug cable: passo 16, imagem 2 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Reposition the spark plug cable: passo 16, imagem 3 %32
    • Use your fingers to reroute the spark plug cable from its slot in the fan cover.
    Pergunte ao FixBot
    Comentar
  17. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Reposition the ignition coil cable: passo 17, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Reposition the ignition coil cable: passo 17, imagem 2 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Reposition the ignition coil cable: passo 17, imagem 3 %32
    • Use your fingers to reroute the ignition coil cable from its slot in the fan cover.
    Pergunte ao FixBot
    Comentar
  18. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Disconnect the ignition coil: passo 18, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Disconnect the ignition coil: passo 18, imagem 2 %32
    • Use pliers, or your fingers, to disconnect the ignition coil cable's spade connector.
    • Grip the connector by the base of the clear head and not the wire itself.
    Pergunte ao FixBot
    Comentar
  19. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Unfasten the ignition coil: passo 19, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Unfasten the ignition coil: passo 19, imagem 2 %32
    • Use a T25 Torx screwdriver to remove the two 20 mm screws securing the ignition coil.
    • During reassembly, insert the ignition air gap gauge to ensure a 0.35 mm space between the coil and the magnet.
    Pergunte ao FixBot
    Comentar
  20. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the ignition coil: passo 20, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the ignition coil: passo 20, imagem 2 %32
    • Remove the ignition coil.
    Pergunte ao FixBot
    Comentar
  21. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the flange nut: passo 21, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the flange nut: passo 21, imagem 2 %32
    • Wedge a flathead screwdriver between the chassis and the flywheel's spokes to prevent the flywheel from spinning.
    • Alternatively, you can seize the piston by inserting a rope down the spark plug shaft.
    • Use a 13 mm wrench to loosen and remove the flange nut located in the middle of the flywheel.
    Pergunte ao FixBot
    Comentar
  22. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Unfasten the starter pawls: passo 22, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Unfasten the starter pawls: passo 22, imagem 2 %32
    • Use a T25 Torx screwdriver to remove the two 16 mm screws securing the starter pawls.
    • Remove the starter pawls.
    Pergunte ao FixBot
    Comentar
  23. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Starter pawl assembly information: passo 23, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Starter pawl assembly information: passo 23, imagem 2 %32
    • During reassembly, be sure to reinstall the starter pawl assembly top to bottom in the following order:
    • 16 mm screw
    • Washer
    • Starter Pawl
    • Spacer
    • Torsion Spring
    Pergunte ao FixBot
    Comentar
  24. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Unfasten the flywheel: passo 24, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Unfasten the flywheel: passo 24, imagem 2 %32
    • Use a flywheel puller to disconnect the flywheel from the woodruff key.
    Pergunte ao FixBot
    Comentar
  25. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the flywheel: passo 25, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the flywheel: passo 25, imagem 2 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the flywheel: passo 25, imagem 3 %32
    • Pull the flywheel straight off of the crankshaft and remove it.
    Pergunte ao FixBot
    Comentar
  26. Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the woodruff key: passo 26, imagem 1 %32 Echo Chain Saw CS590 2019 Woodruff Key Replacement, Remove the woodruff key: passo 26, imagem 2 %32
    • Insert a flathead screwdriver into the gap at the top of the woodruff key.
    • Pry with the screwdriver to separate the key from the crankshaft.
    Pergunte ao FixBot
    Comentar
  27. Echo Chain Saw CS590 2019 Woodruff Key Replacement: passo 27, imagem 1 %32
    • Use pliers, or your fingers, to remove the woodruff key.
    • During reassembly, be sure to reinsert the woodruff key with the flat side facing outward.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
238.691 Reputação
Autoria de 1.171 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 25.930 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 16
Últimos 30 dias: 69
Ao todo: 1,223
