Ir para o conteúdo principal
Echo Chain Saw CS590 2019 Front Hand Guard Replacement
O que você precisa
  1. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Turn off the chainsaw: passo 1, imagem 1 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Turn off the chainsaw: passo 1, imagem 2 %32
    • Make sure you have the ignition switch turned off before starting your repair.
    • The chainsaw should be cool to the touch before continuing.
  2. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Loosen the air filter cover: passo 2, imagem 1 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Loosen the air filter cover: passo 2, imagem 2 %32
    • Use your fingers to loosen the air filter cover knob.
  3. Echo Chain Saw CS590 2019 Front Hand Guard Replacement: passo 3, imagem 1 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement: passo 3, imagem 2 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement: passo 3, imagem 3 %32
    • Remove the air filter cover.
  4. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Disconnect the spark plug: passo 4, imagem 1 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Disconnect the spark plug: passo 4, imagem 2 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Disconnect the spark plug: passo 4, imagem 3 %32
    • Use your fingers to pull up and disconnect the spark plug boot.
  5. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the air filter: passo 5, imagem 1 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the air filter: passo 5, imagem 2 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the air filter: passo 5, imagem 3 %32
    • To minimize debris entering the intake, pull the choke shut before continuing.
    • During reassembly, clean the air filter with compressed air or with light brushing before reinstalling it.
  6. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Unfasten the front handle: passo 6, imagem 1 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Unfasten the front handle: passo 6, imagem 2 %32
    • Use a T25 Torx screwdriver to remove the five screws securing the front handle to the bottom and right side of the device:
    • Four 24 mm-long screws
    • One 25 mm-long screw
  7. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the front handle: passo 7, imagem 1 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the front handle: passo 7, imagem 2 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the front handle: passo 7, imagem 3 %32
    • Pull the handle toward the rear of the device to remove it.
  8. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the sprocket guard: passo 8, imagem 1 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the sprocket guard: passo 8, imagem 2 %32
    • Use a 13 mm wrench to remove the two nuts securing the sprocket guard.
  9. Echo Chain Saw CS590 2019 Front Hand Guard Replacement: passo 9, imagem 1 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement: passo 9, imagem 2 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement: passo 9, imagem 3 %32
    • Remove the sprocket guard.
  10. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the guide bar: passo 10, imagem 1 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the guide bar: passo 10, imagem 2 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the guide bar: passo 10, imagem 3 %32
    • Push the guide bar towards the back of the device to create slack in the saw chain.
    • Pull the guide bar away from the device to separate the saw chain from the clutch drum.
    • Remove the guide bar.
  11. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Unfasten the front hand guard: passo 11, imagem 1 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Unfasten the front hand guard: passo 11, imagem 2 %32
    • Make sure the front hand guard is in the unlocked position before continuing.
    • Use a T25 Torx screwdriver to remove the two 20 mm screws securing the front hand guard.
  12. Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the front hand guard: passo 12, imagem 1 %32 Echo Chain Saw CS590 2019 Front Hand Guard Replacement, Remove the front hand guard: passo 12, imagem 2 %32
    • Pull the front hand guard toward the rear of the device to remove it.
Conclusão
3 outras pessoas executaram este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
163.291 Reputação
Autoria de 769 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.541 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 63
Ao todo: 1,156
