Ir para o conteúdo principal
Echo Chain Saw CS590 2019 Flywheel Replacement
O que você precisa
  1. Echo Chain Saw CS590 2019 Flywheel Replacement, Turn off the chainsaw: passo 1, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Turn off the chainsaw: passo 1, imagem 2 %32
    • Make sure you have the ignition switch turned off before starting your repair.
    • The chainsaw should be cool to the touch before continuing.
  2. Echo Chain Saw CS590 2019 Flywheel Replacement, Loosen the air filter cover: passo 2, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Loosen the air filter cover: passo 2, imagem 2 %32
    • Use your fingers to loosen the air filter cover knob.
  3. Echo Chain Saw CS590 2019 Flywheel Replacement: passo 3, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement: passo 3, imagem 2 %32 Echo Chain Saw CS590 2019 Flywheel Replacement: passo 3, imagem 3 %32
    • Remove the air filter cover.
  4. Echo Chain Saw CS590 2019 Flywheel Replacement, Disconnect the spark plug: passo 4, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Disconnect the spark plug: passo 4, imagem 2 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Disconnect the spark plug: passo 4, imagem 3 %32
    • Use your fingers to pull up and disconnect the spark plug boot.
  5. Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the air filter: passo 5, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the air filter: passo 5, imagem 2 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the air filter: passo 5, imagem 3 %32
    • To minimize debris entering the intake, pull the choke shut before continuing.
    • During reassembly, clean the air filter with compressed air or with light brushing before reinstalling it.
  6. Echo Chain Saw CS590 2019 Flywheel Replacement, Unfasten the front handle: passo 6, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Unfasten the front handle: passo 6, imagem 2 %32
    • Use a T25 Torx screwdriver to remove the five screws securing the front handle to the bottom and right side of the device:
    • Four 24 mm-long screws
    • One 25 mm-long screw
  7. Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the front handle: passo 7, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the front handle: passo 7, imagem 2 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the front handle: passo 7, imagem 3 %32
    • Pull the handle toward the rear of the device to remove it.
  8. Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the sprocket guard: passo 8, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the sprocket guard: passo 8, imagem 2 %32
    • Use a 13 mm wrench to remove the two nuts securing the sprocket guard.
  9. Echo Chain Saw CS590 2019 Flywheel Replacement: passo 9, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement: passo 9, imagem 2 %32 Echo Chain Saw CS590 2019 Flywheel Replacement: passo 9, imagem 3 %32
    • Remove the sprocket guard.
  10. Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the guide bar: passo 10, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the guide bar: passo 10, imagem 2 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the guide bar: passo 10, imagem 3 %32
    • Push the guide bar towards the back of the device to create slack in the saw chain.
    • Pull the guide bar away from the device to separate the saw chain from the clutch drum.
    • Remove the guide bar.
  11. Echo Chain Saw CS590 2019 Flywheel Replacement, Unfasten the front hand guard: passo 11, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Unfasten the front hand guard: passo 11, imagem 2 %32
    • Make sure the front hand guard is in the unlocked position before continuing.
    • Use a T25 Torx screwdriver to remove the two 20 mm screws securing the front hand guard.
  12. Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the front hand guard: passo 12, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the front hand guard: passo 12, imagem 2 %32
    • Pull the front hand guard toward the rear of the device to remove it.
  13. Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the engine cover: passo 13, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the engine cover: passo 13, imagem 2 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the engine cover: passo 13, imagem 3 %32
    • Pull the engine cover straight off the device to remove it.
  14. Echo Chain Saw CS590 2019 Flywheel Replacement, Unfasten the starter case: passo 14, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Unfasten the starter case: passo 14, imagem 2 %32
    • Use a T25 Torx screwdriver to remove the four 24 mm screws securing the starter case.
  15. Echo Chain Saw CS590 2019 Flywheel Replacement: passo 15, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement: passo 15, imagem 2 %32 Echo Chain Saw CS590 2019 Flywheel Replacement: passo 15, imagem 3 %32
    • Remove the starter case.
  16. Echo Chain Saw CS590 2019 Flywheel Replacement, Reposition the spark plug cable: passo 16, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Reposition the spark plug cable: passo 16, imagem 2 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Reposition the spark plug cable: passo 16, imagem 3 %32
    • Use your fingers to reroute the spark plug cable from its slot in the fan cover.
  17. Echo Chain Saw CS590 2019 Flywheel Replacement, Reposition the ignition coil cable: passo 17, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Reposition the ignition coil cable: passo 17, imagem 2 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Reposition the ignition coil cable: passo 17, imagem 3 %32
    • Use your fingers to reroute the ignition coil cable from its slot in the fan cover.
  18. Echo Chain Saw CS590 2019 Flywheel Replacement, Disconnect the ignition coil: passo 18, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Disconnect the ignition coil: passo 18, imagem 2 %32
    • Use pliers, or your fingers, to disconnect the ignition coil cable's spade connector.
    • Grip the connector by the base of the clear head and not the wire itself.
  19. Echo Chain Saw CS590 2019 Flywheel Replacement, Unfasten the ignition coil: passo 19, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Unfasten the ignition coil: passo 19, imagem 2 %32
    • Use a T25 Torx screwdriver to remove the two 20 mm screws securing the ignition coil.
    • During reassembly, insert the ignition air gap gauge to ensure a 0.35 mm space between the coil and the magnet.
  20. Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the ignition coil: passo 20, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the ignition coil: passo 20, imagem 2 %32
    • Remove the ignition coil.
  21. Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the flange nut: passo 21, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the flange nut: passo 21, imagem 2 %32
    • Wedge a flathead screwdriver between the chassis and the flywheel's spokes to prevent the flywheel from spinning.
    • Alternatively, you can seize the piston by inserting a rope down the spark plug shaft.
    • Use a 13 mm wrench to loosen and remove the flange nut located in the middle of the flywheel.
  22. Echo Chain Saw CS590 2019 Flywheel Replacement, Unfasten the starter pawls: passo 22, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Unfasten the starter pawls: passo 22, imagem 2 %32
    • Use a T25 Torx screwdriver to remove the two 16 mm screws securing the starter pawls.
    • Remove the starter pawls.
  23. Echo Chain Saw CS590 2019 Flywheel Replacement, Starter pawl assembly information: passo 23, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Starter pawl assembly information: passo 23, imagem 2 %32
    • During reassembly, be sure to reinstall the starter pawl assembly top to bottom in the following order:
    • 16 mm screw
    • Washer
    • Starter Pawl
    • Spacer
    • Torsion Spring
  24. Echo Chain Saw CS590 2019 Flywheel Replacement, Unfasten the flywheel: passo 24, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Unfasten the flywheel: passo 24, imagem 2 %32
    • Use a flywheel puller to disconnect the flywheel from the woodruff key.
  25. Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the flywheel: passo 25, imagem 1 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the flywheel: passo 25, imagem 2 %32 Echo Chain Saw CS590 2019 Flywheel Replacement, Remove the flywheel: passo 25, imagem 3 %32
    • Pull the flywheel straight off of the crankshaft and remove it.
Conclusão
3 outras pessoas executaram este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
230.080 Reputação
Autoria de 1.106 guias
Equipe
iFixit Membro de iFixit
Staff
124 Membros
Autoria de 25.044 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 83
Ao todo: 2,173
