Ir para o conteúdo principal
Echo Chain Saw CS4910 2020 Carburetor Replacement
O que você precisa
  1. Echo Chain Saw CS4910 2020 Carburetor Replacement, Turn off the chainsaw: passo 1, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Turn off the chainsaw: passo 1, imagem 2 %32
    • Make sure you have the ignition switch turned off before starting your repair.
    • The chainsaw should be cool to the touch before continuing.
  2. Echo Chain Saw CS4910 2020 Carburetor Replacement, Loosen the air filter cover: passo 2, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Loosen the air filter cover: passo 2, imagem 2 %32
    • Use your fingers to loosen the air filter cover knob.
  3. Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter cover: passo 3, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter cover: passo 3, imagem 2 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter cover: passo 3, imagem 3 %32
    • Remove the air filter cover.
  4. Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter: passo 4, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter: passo 4, imagem 2 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter: passo 4, imagem 3 %32
    • During reassembly, clean the air filter with compressed air or with light brushing before reinstalling it.
  5. Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the spark plug: passo 5, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the spark plug: passo 5, imagem 2 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the spark plug: passo 5, imagem 3 %32
    • Use your fingers to pull up and disconnect the spark plug boot.
  6. Echo Chain Saw CS4910 2020 Carburetor Replacement, Loosen the sprocket guard: passo 6, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Loosen the sprocket guard: passo 6, imagem 2 %32
    • Use a 13 mm wrench to loosen and remove the two nuts securing the sprocket guard.
  7. Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the sprocket guard: passo 7, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the sprocket guard: passo 7, imagem 2 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the sprocket guard: passo 7, imagem 3 %32
    • Pull the sprocket guard straight off its two pegs and remove it.
  8. Echo Chain Saw CS4910 2020 Carburetor Replacement, Unclip the saw chain: passo 8, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Unclip the saw chain: passo 8, imagem 2 %32
    • Put on gloves before performing the next two steps.
    • Pull the saw chain away from the tip of the guide bar to unclip it.
  9. Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the guide bar: passo 9, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the guide bar: passo 9, imagem 2 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the guide bar: passo 9, imagem 3 %32
    • Push the guide bar towards the back of the device to unclip the rest of the saw chain.
    • Pull the guide bar away from the device to separate the saw chain from the clutch drum.
    • Remove the guide bar and the saw chain.
  10. Echo Chain Saw CS4910 2020 Carburetor Replacement, Unfasten the engine cover: passo 10, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Unfasten the engine cover: passo 10, imagem 2 %32
    • Use a flathead screwdriver, or a 3 mm hex key, to remove the three 18 mm screws securing the engine cover.
  11. Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the engine cover: passo 11, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the engine cover: passo 11, imagem 2 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the engine cover: passo 11, imagem 3 %32
    • Pull the engine cover straight up off the engine.
    • Remove the engine cover.
  12. Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the carburetor: passo 12, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the carburetor: passo 12, imagem 2 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the carburetor: passo 12, imagem 3 %32
    • Before performing this step, put on safety glasses to avoid any fuel spraying in your eyes.
    • Use your fingers to pull the top-most fuel pipe out of the carburetor.
  13. Echo Chain Saw CS4910 2020 Carburetor Replacement: passo 13, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement: passo 13, imagem 2 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement: passo 13, imagem 3 %32
    • Lift the choke rod out of its recess in the chassis.
    • Twist the rod counter-clockwise to disconnect it from the carburetor.
    • Remove the choke rod.
  14. Echo Chain Saw CS4910 2020 Carburetor Replacement, Unfasten the carburetor: passo 14, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Unfasten the carburetor: passo 14, imagem 2 %32
    • Remove the four screws securing the carburetor and the air filter adapter:
    • Use a 3 mm hex key to remove the two 20 mm-long screws.
    • Use a 4 mm hex key to remove the two 53 mm-long screws.
  15. Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter adapter: passo 15, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter adapter: passo 15, imagem 2 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the air filter adapter: passo 15, imagem 3 %32
    • Pull the air filter adapter straight off the carburetor and remove it.
  16. Echo Chain Saw CS4910 2020 Carburetor Replacement, Reposition the carburetor: passo 16, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Reposition the carburetor: passo 16, imagem 2 %32
    • With the carburetor's choke valve facing you, tilt the carburetor up and to the left to expose the right-most fuel pipe.
  17. Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the right fuel pipe: passo 17, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Disconnect the right fuel pipe: passo 17, imagem 2 %32
    • Use your fingers to disconnect the right-most fuel pipe.
  18. Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the carburetor: passo 18, imagem 1 %32 Echo Chain Saw CS4910 2020 Carburetor Replacement, Remove the carburetor: passo 18, imagem 2 %32
    • Lift the carburetor straight off the throttle rod and remove it.
    • Realign throttle rod upon reassembly.
Conclusão
Alex Diaz-Kokaisl
Membro desde: 01/16/22
163.378 Reputação
Autoria de 770 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.581 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 38
Ao todo: 1,131
