Ir para o conteúdo principal
Echo Chain Saw CS-590 (2019) Ignition Coil Replacement
O que você precisa
  1. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Turn off the chainsaw: passo 1, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Turn off the chainsaw: passo 1, imagem 2 %32
    • Make sure you have the ignition switch turned off before starting your repair.
    • The chainsaw should be cool to the touch before continuing.
    Pergunte ao FixBot
    Comentar
  2. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Loosen the air filter cover: passo 2, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Loosen the air filter cover: passo 2, imagem 2 %32
    • Use your fingers to loosen the air filter cover knob.
    Pergunte ao FixBot
    Comentar
  3. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement: passo 3, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement: passo 3, imagem 2 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement: passo 3, imagem 3 %32
    • Remove the air filter cover.
    Pergunte ao FixBot
    Comentar
  4. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Disconnect the spark plug: passo 4, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Disconnect the spark plug: passo 4, imagem 2 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Disconnect the spark plug: passo 4, imagem 3 %32
    • Use your fingers to pull up and disconnect the spark plug boot.
    Pergunte ao FixBot
    Comentar
  5. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the air filter: passo 5, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the air filter: passo 5, imagem 2 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the air filter: passo 5, imagem 3 %32
    • To minimize debris entering the intake, pull the choke shut before continuing.
    • During reassembly, clean the air filter with compressed air or with light brushing before reinstalling it.
    Pergunte ao FixBot
    Comentar
  6. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Unfasten the front handle: passo 6, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Unfasten the front handle: passo 6, imagem 2 %32
    • Use a T25 Torx screwdriver to remove the five screws securing the front handle to the bottom and right side of the device:
    • Four 24 mm-long screws
    • One 25 mm-long screw
    Pergunte ao FixBot
    Comentar
  7. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the front handle: passo 7, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the front handle: passo 7, imagem 2 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the front handle: passo 7, imagem 3 %32
    • Pull the handle toward the rear of the device to remove it.
    Pergunte ao FixBot
    Comentar
  8. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the sprocket guard: passo 8, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the sprocket guard: passo 8, imagem 2 %32
    • Use a 13 mm wrench to remove the two nuts securing the sprocket guard.
    Pergunte ao FixBot
    Comentar
  9. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement: passo 9, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement: passo 9, imagem 2 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement: passo 9, imagem 3 %32
    • Remove the sprocket guard.
    Pergunte ao FixBot
    Comentar
  10. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the guide bar: passo 10, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the guide bar: passo 10, imagem 2 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the guide bar: passo 10, imagem 3 %32
    • Push the guide bar towards the back of the device to create slack in the saw chain.
    • Pull the guide bar away from the device to separate the saw chain from the clutch drum.
    • Remove the guide bar.
    Pergunte ao FixBot
    Comentar
  11. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Unfasten the front hand guard: passo 11, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Unfasten the front hand guard: passo 11, imagem 2 %32
    • Make sure the front hand guard is in the unlocked position before continuing.
    • Use a T25 Torx screwdriver to remove the two 20 mm screws securing the front hand guard.
    Pergunte ao FixBot
    Comentar
  12. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the front hand guard: passo 12, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the front hand guard: passo 12, imagem 2 %32
    • Pull the front hand guard toward the rear of the device to remove it.
    Pergunte ao FixBot
    Comentar
  13. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the engine cover: passo 13, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the engine cover: passo 13, imagem 2 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the engine cover: passo 13, imagem 3 %32
    • Pull the engine cover straight off the device to remove it.
    Pergunte ao FixBot
    Comentar
  14. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Unfasten the starter case: passo 14, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Unfasten the starter case: passo 14, imagem 2 %32
    • Use a T25 Torx screwdriver to remove the four 24 mm screws securing the starter case.
    Pergunte ao FixBot
    Comentar
  15. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement: passo 15, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement: passo 15, imagem 2 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement: passo 15, imagem 3 %32
    • Remove the starter case.
    Pergunte ao FixBot
    Comentar
  16. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Reposition the spark plug cable: passo 16, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Reposition the spark plug cable: passo 16, imagem 2 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Reposition the spark plug cable: passo 16, imagem 3 %32
    • Use your fingers to reroute the spark plug cable from its slot in the fan cover.
    Pergunte ao FixBot
    Comentar
  17. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Reposition the ignition coil cable: passo 17, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Reposition the ignition coil cable: passo 17, imagem 2 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Reposition the ignition coil cable: passo 17, imagem 3 %32
    • Use your fingers to reroute the ignition coil cable from its slot in the fan cover.
    Pergunte ao FixBot
    Comentar
  18. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Disconnect the ignition coil: passo 18, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Disconnect the ignition coil: passo 18, imagem 2 %32
    • Use pliers, or your fingers, to disconnect the ignition coil cable's spade connector.
    • Grip the connector by the base of the clear head and not the wire itself.
    Pergunte ao FixBot
    Comentar
  19. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Unfasten the ignition coil: passo 19, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Unfasten the ignition coil: passo 19, imagem 2 %32
    • Use a T25 Torx screwdriver to remove the two 20 mm screws securing the ignition coil.
    • During reassembly, insert the ignition air gap gauge to ensure a 0.35 mm space between the coil and the magnet.
    Pergunte ao FixBot
    Comentar
  20. Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the ignition coil: passo 20, imagem 1 %32 Echo Chain Saw CS-590 (2019) Ignition Coil Replacement, Remove the ignition coil: passo 20, imagem 2 %32
    • Remove the ignition coil.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
244.459 Reputação
Autoria de 1.203 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 27.589 guias
3Comentários do guia
Useless. This shows nothing about having to put the sparkplug connection onto the coil which was sent WITHOUT
that connector.
KEVIN - Responder Compartilhar
Most of them have a self-tapping screw in the rubber cap and you just screw it onto the wire.
Truman Fancher - Responder Compartilhar
Do not show how to connect spark plug connector into plug boot , there is no connector with new coil ,there is no self tapping screw with coil lead
LOUIS - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 24
Últimos 30 dias: 185
Ao todo: 4,252
