Ir para o conteúdo principal
Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement
O que você precisa
  1. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Disconnect the spark plug wire: passo 1, imagem 1 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Disconnect the spark plug wire: passo 1, imagem 2 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Disconnect the spark plug wire: passo 1, imagem 3 %32
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grip the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Disconnect the control cables: passo 2, imagem 1 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Disconnect the control cables: passo 2, imagem 2 %32
    • Unclip the throttle cable routing clip from the main shaft.
  3. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 3, imagem 1 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 3, imagem 2 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 3, imagem 3 %32
    • Grip both ends of one of the control cable bullet connectors and pull to disconnect it.
    • Repeat to disconnect the second control cable connector.
    • These connectors are interchangeable.
  4. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Remove the muffler cover: passo 4, imagem 1 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Remove the muffler cover: passo 4, imagem 2 %32
    • This Echo device has an included multi-tool with a T30 Torx screwdriver, but any T30 Torx driver is compatible.
    • Use a T30 Torx driver to remove the two screws securing the muffler cover.
  5. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 5, imagem 1 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 5, imagem 2 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 5, imagem 3 %32
    • Lift the muffler cover up and pivot it on its top edge to unlatch it from the engine cover.
    • Remove the muffler cover.
  6. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Remove the engine cover: passo 6, imagem 1 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Remove the engine cover: passo 6, imagem 2 %32
    • Use a T30 Torx driver to remove the two screws securing the engine cover.
  7. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 7, imagem 1 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 7, imagem 2 %32
    • Lift the engine cover straight up to remove it.
  8. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Remove the fan cover: passo 8, imagem 1 %32
    • Use a T30 Torx driver to remove the two screws securing the fan cover.
  9. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 9, imagem 1 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 9, imagem 2 %32
    • Pull the fan cover away from the motor assembly.
  10. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Reassembly tip: passo 10, imagem 1 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Reassembly tip: passo 10, imagem 2 %32
    • During reassembly:
    • Reroute the two control cables through the opening on the fan cover.
    • Lay the cables into their slot on the clutch cover.
  11. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Separate the shaft from the engine assembly: passo 11, imagem 1 %32
    • Use a T30 Torx driver to loosen, but not remove, the collar bolt securing the main shaft to the engine assembly.
  12. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 12, imagem 1 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 12, imagem 2 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 12, imagem 3 %32
    • Grip the engine assembly and pull to remove it from the main shaft.
    • With the engine assembly removed, take care to not put any strain on the still-connected throttle cable.
  13. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Remove the clutch cover: passo 13, imagem 1 %32
    • Use a T30 Torx driver to remove the two screws securing the clutch cover.
  14. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 14, imagem 1 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 14, imagem 2 %32
    • Remove the clutch cover.
  15. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Remove the clutch assembly: passo 15, imagem 1 %32
    • Use a 1/2 inch socket to remove the two 12 mm-long bolts and four accompanying washers securing the clutch assembly.
    • Note that the larger washer goes underneath the clutch assembly and the small washer goes above.
    • Ensure that the clutch assembly is reinstalled arrow side up.
  16. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 16, imagem 1 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement: passo 16, imagem 2 %32
    • Remove the clutch assembly.
  17. Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Remove the clutch shoes: passo 17, imagem 1 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Remove the clutch shoes: passo 17, imagem 2 %32 Echo Brushcutter SRM2620U 2017 Clutch Shoes Replacement, Remove the clutch shoes: passo 17, imagem 3 %32
    • Firmly grip one clutch shoe in each hand and twist them apart to release the spring tension.
    • During reassembly, loop the clutch spring in place on the clutch shoes and twist them together to reapply spring tension.
    • Disconnect one side of the spring loop from one of the clutch shoes.
    • Disconnect the spring from the second clutch shoe.
    • Remove both clutch shoes.
Conclusão
Carsten Frauenheim
Membro desde: 03/10/20
138.551 Reputação
Autoria de 379 guias
Equipe
iFixit Membro de iFixit
Staff
121 Membros
Autoria de 19.829 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 210
