Ir para o conteúdo principal
EasySMX ESM-9110 Backplate Replacement
O que você precisa
  1. EasySMX ESM-9110 Backplate Replacement, Handle Covers: passo 1, imagem 1 %32 EasySMX ESM-9110 Backplate Replacement, Handle Covers: passo 1, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
  2. EasySMX ESM-9110 Backplate Replacement: passo 2, imagem 1 %32
    • Insert a plastic opening tool into the slit on the side of controller.
    • Wiggle the tool until the cover becomes loose.
    • Repeat this on the other side of Controller.
    • Go slow. Take your time removing the handle covers.
  3. EasySMX ESM-9110 Backplate Replacement: passo 3, imagem 1 %32
    • Remove the faceplate.
    • Repeat on the other side of the controller.
  4. EasySMX ESM-9110 Backplate Replacement, Backplate: passo 4, imagem 1 %32 EasySMX ESM-9110 Backplate Replacement, Backplate: passo 4, imagem 2 %32 EasySMX ESM-9110 Backplate Replacement, Backplate: passo 4, imagem 3 %32
    • Use a Phillips #000 screwdriver to remove four 20 mm screws from the controller's faceplate.
    • Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
    • Screw extender should only be used to unscrew two of the six screws. Do not use for all six.
  5. EasySMX ESM-9110 Backplate Replacement: passo 5, imagem 1 %32
    • Remove the faceplate of the controller by lifting it directly up from the backplate.
    • Be gentle. The controllers backplate is still attached to the faceplate.
  6. EasySMX ESM-9110 Backplate Replacement: passo 6, imagem 1 %32 EasySMX ESM-9110 Backplate Replacement: passo 6, imagem 2 %32 EasySMX ESM-9110 Backplate Replacement: passo 6, imagem 3 %32
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the daughterboard off the backplate.
    • Remove the daughterboard once screws are off.
    • Be gentle when removing the daughterboard. The daughterboard is still attached to the faceplate.
Conclusão
Melanie Rodriguez
Membro desde: 03/18/24
373 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 2-4, Konn Spring 2024 Membro de UMass Dartmouth, Team 2-4, Konn Spring 2024
UMASSD-KONN-S24S2G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 56
