Introdução
This guide will teach you how to replace the backplate of the EasySMX ESM-9110 controller.
O que você precisa
Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
Use a Phillips #000 screwdriver to remove four 20 mm screws from the controller's faceplate.
Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
Quase terminado!
Conclusão
