Ir para o conteúdo principal
EasySMX ESM-9100 Face Buttons Replacement
O que você precisa
  1. EasySMX ESM-9100 Face Buttons Replacement, Bottom Case: passo 1, imagem 1 %32
    • Place the controller face down on a solid surface.
    • Use a Phillips #00 screwdriver to remove the seven 10 mm screws from the back cover.
    • The order does not matter.
  2. EasySMX ESM-9100 Face Buttons Replacement: passo 2, imagem 1 %32 EasySMX ESM-9100 Face Buttons Replacement: passo 2, imagem 2 %32 EasySMX ESM-9100 Face Buttons Replacement: passo 2, imagem 3 %32
    • Use the iFixit opening tool to pry off the back cover and remove it to reveal the internal components.
    • Place the cover off to the side, then grab the circuit board and gently remove it from the front cover.
    • Be careful when removing the back cover, the components in this controller are loosely attached and can fall out easily.
  3. EasySMX ESM-9100 Face Buttons Replacement, A/B/X/Y Buttons: passo 3, imagem 1 %32 EasySMX ESM-9100 Face Buttons Replacement, A/B/X/Y Buttons: passo 3, imagem 2 %32
    • Gently pull out the buttons by the rubber backing from the top cover.
    • Be gentle so the buttons don't fall off the rubber back as you pull it out.
  4. EasySMX ESM-9100 Face Buttons Replacement: passo 4, imagem 1 %32 EasySMX ESM-9100 Face Buttons Replacement: passo 4, imagem 2 %32
    • Gently pull each face button off of the rubber backing.
    • The buttons should be on the rubber in order of Y at the top, B to the right, A at the bottom, and X to the left.
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
Alex Vala
Membro desde: 03/19/24
746 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 4-4, Shaddix Spring 2024 Membro de UMass Dartmouth, Team 4-4, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G4
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 25
Duração total: 75
