Ir para o conteúdo principal
EasySMX ESM-9100 D-Pad Replacement
O que você precisa
  1. EasySMX ESM-9100 D-Pad Replacement, Bottom Case: passo 1, imagem 1 %32
    • Place the controller face down on a solid surface.
    • Use a Phillips #00 screwdriver to remove the seven 10 mm screws from the back cover.
    • The order does not matter.
  2. EasySMX ESM-9100 D-Pad Replacement: passo 2, imagem 1 %32 EasySMX ESM-9100 D-Pad Replacement: passo 2, imagem 2 %32 EasySMX ESM-9100 D-Pad Replacement: passo 2, imagem 3 %32
    • Use the iFixit opening tool to pry off the back cover and remove it to reveal the internal components.
    • Place the cover off to the side, then grab the circuit board and gently remove it from the front cover.
    • Be careful when removing the back cover, the components in this controller are loosely attached and can fall out easily.
  3. EasySMX ESM-9100 D-Pad Replacement, D-Pad: passo 3, imagem 1 %32 EasySMX ESM-9100 D-Pad Replacement, D-Pad: passo 3, imagem 2 %32
    • Gently remove the rubber off the circuit board that corresponds with the d-pad.
    • Be careful to not damage the rubber which has two excess pieces that hang off of it and slot into the circuit board.
  4. EasySMX ESM-9100 D-Pad Replacement: passo 4, imagem 1 %32
    • Gently push the d-pad back into the socket by pressing on it lightly.
    • The d-pad fits securely in the cover and cannot be removed without breaking the cover. Do not use excessive force when pushing it into place, as you may break the top cover.
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
Alex Vala
Membro desde: 03/19/24
746 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 4-4, Shaddix Spring 2024 Membro de UMass Dartmouth, Team 4-4, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G4
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 78
