Ir para o conteúdo principal
EVGA GeForce GTX 1080 FTW2 DT GAMING with iCX Cooler PCIe Mounting plate Removal
O que você precisa
    • If you have any dust caps over the HDMI or Display Port connections, remove them
  1. EVGA GeForce GTX 1080 FTW2 DT GAMING with iCX Cooler PCIe Mounting plate Removal, Remove Back Screws: passo 2, imagem 1 %32
    • Remove the 3 screws using a Phillips #1 Screwdriver (Red)
    • Remove the 2 Standoffs using a 5mm socket
  2. EVGA GeForce GTX 1080 FTW2 DT GAMING with iCX Cooler PCIe Mounting plate Removal: passo 3, imagem 1 %32 EVGA GeForce GTX 1080 FTW2 DT GAMING with iCX Cooler PCIe Mounting plate Removal: passo 3, imagem 2 %32
    • Remove top screw using a Phillips #0 screwdriver (Blue)
    • Remove the bottom screw and nut using a Phillips #0 screwdriver. Will want to use a finger to hold the nut from spinning while releasing the screw.
    • Gently slide the plate out from between the back cover and the circuit board. It should come out without much force.
    • If it doesn't want to budge, check that the right screw was removed from the top of the video card.
Conclusão
Wolphin
Membro desde: 11/11/19
1.771 Reputação
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 39
Duração total: 797
