Introdução
I'm going to show how you how I installed the EMG ALX Humbucker with the ABQ Boost into an ESP Alexi Laiho signature guitar.
Peças
Now just take the poti out, take the wires and... Oh, where is the green cable the instruction from EMG told us from? In fact, it is missing...
But that doesn't matter, just take any cable you can find, and act like it was the green cable, because this is the only cable that doesn't have a special connector like the others.
Well, it's not only the green cable that is missing, but the second cable one has to pull through the outputjack hole is too short... And again, that doesn't matter, just cut that cable in the center, take the old outputcable that was in the guitar anyway and solder it, and there it is, the long-enough cable for the outputjack.
I just isolated the solderconnections with adhesive tape.
Now connect everything like it is said in the instruction.
Again you have to solder the "green" cable, but it's an easy solderconnection. Again I isolated it with adhesive tape.
You can place the battery in the electronic box, just fix it with foam plastic or something like that.
Now just place the poti and bolt it down.
Finnished.
Uma outra pessoa concluiu este guia.
