Introdução
For most repairs the ESGE Magic Wand - Bamix has to be disassembled.
O que você precisa
Ferramenta utilizada nesse passo:iFixit Precision 4 mm Screwdriver Bit$2.99
Remove two Torx TR10 screws.
Carefully lift off the cover. It is latched at the front.
First try If the bell can be unscrewed. It is fastened with a left-hand thread, so turn it in the "wrong direction", clockwise, to loosen it.
Pull on the knife to remove it
If it does not come off easily, then slide the lower plastic part towards the bell and clamp the motor in a vice. Do not tighten the vice very much, the motor is sensitive.
Use a long screwdriver as a lever between the bell and the shaft. Then carefully unscrew the bell. Reminder: the wrong way round, i.e. clockwise.
Pay attention to the washer between the shaft and the bell, do not lose it.
Uma outra pessoa concluiu este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
2 comentários
Danke für die Anleitung.
Mein Zauberstab fängt sehr schnell an schleppend zu laufen (irgendwo entsteht Wiederstand), wird langsamer, wenn ich heisse Sachen püriere. Woran könnte das liegen?
LG Aaron
Da würde ich wirklich die Achse freilegen und mit etwas Silikonöl schmieren.
VauWeh -
