Introdução
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Follow this guide to remove and replace the blade retainer on an EDCO Floor Stripper TS8 .75L (2017).
The hood is removed in the photos, but the procedure is the same.
O que você precisa
Ensure the machine is unplugged.
Turn the power switch counterclockwise into the OFF position.
Insert wheel chocks behind the wheels to ensure the device does not move or fall during the repair."
Use a 3/16 inch hex key to remove the three bolts securing the blade retainer.
