Introdução
Follow this guide to replace the sheave on an EDCO Disk Grinder model 50200-HD.
This repair requires two people.
O que você precisa
Ensure the machine is unplugged.
Turn the power switch counterclockwise into the OFF position.
Use a 9/16 inch socket to remove the two bolts securing the weighted hood.
Use a 5/32 inch hex wrench to loosen the set screw securing the sheave to the head assembly shaft.
Quase terminado!
Conclusão
