Introdução
The interior door handles on E90 3 Series BMWs commonly fail, becoming sticky or deformed over time, but this handy guide will help the user to fix the handle themselves. The guide has every part or tool listed that you'll need. However, there are a couple of things to be mindful of during the process.
When you initially have the door opened, make sure you lock the door before starting the repair so the locking mechanism does not malfunction during your repair. Not doing so can result in having to do more work that is unnecessary. Another tip is to make sure that your electrical connections aren't disconnected. If you do decide to disconnect any electrical components, take pictures of where the connections are so you may know where to plug things back in while safely operating in the repair as well as wear gloves and use electrical tape if needed.
Turn your vehicle off before beginning.
O que você precisa
Lock the door.
Use the trim removal tool to pry off the silver trim, working from left to right.
Enjoy your brand-new handle!
Uma outra pessoa concluiu este guia.
