Ir para o conteúdo principal
E46 M3 door card/panel removal
O que você precisa
  1. E46 M3 door card/panel removal, Identify the screws: passo 1, imagem 1 %32
    • The door card is held securely in place with 5 screws.
    • Keep in mind the door card has up to 3 wire bundles attached to it. Be careful when removing it! Be prepared to support it while dealing with the wires.
  2. E46 M3 door card/panel removal, Remove screw covers: passo 2, imagem 1 %32 E46 M3 door card/panel removal, Remove screw covers: passo 2, imagem 2 %32
    • Using a spudger, work off the cap of the first screw. The cap is tight; you may need a jimmy or metal spudger.
    • Using the flat end of a spudger, remove the airbag emblem. The emblem has clips on the top and bottom -- work carefully.
  3. E46 M3 door card/panel removal, Remove bolts: passo 3, imagem 1 %32
    • Using a T20 Torx driver with extension, remove all 5 bolts.
  4. E46 M3 door card/panel removal, Remove mirror control: passo 4, imagem 1 %32
    • If you're working on the driver side door, remove the mirror control module. Disconnect it from its wiring plug.
  5. E46 M3 door card/panel removal, Pop door card clips: passo 5, imagem 1 %32 E46 M3 door card/panel removal, Pop door card clips: passo 5, imagem 2 %32
    • Using a trim tool or similar, begin at the bottom of the door card and pop the card away from the door frame.
    • After you've released the bottom clips, work your way around.
    • You will need to lift the door card from the door frame in order to fully release it. Be careful!
    • Disconnect the following from the door panel:
    • Unlocking cable
    • Speaker cable(s)
    • Set the door panel aside.
  6. E46 M3 door card/panel removal, Door panel removed!: passo 7, imagem 1 %32
    • The door panel is now removed.
    • You will see the airbag module, vapor barrier, and other components.
Conclusão
To reassemble your door, follow these instructions in reverse order.
4 outras pessoas executaram este guia.
Dom Santangelo
Membro desde: 09/19/16
592 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 46
Últimos 30 dias: 151
Duração total: 14,750
