Ir para o conteúdo principal
Dyson V8 Absolute Battery Replacement
O que você precisa
  1. Dyson V8 Absolute Battery Replacement, Battery: passo 1, imagem 1 %32 Dyson V8 Absolute Battery Replacement, Battery: passo 1, imagem 2 %32
    • Detach wand from device.
    • Use a Phillips #2 screwdriver to unscrew the screw from the device handle.
    • Screw Head Type: Phillips #2
    • Screw Length: 170mm
  2. Dyson V8 Absolute Battery Replacement: passo 2, imagem 1 %32 Dyson V8 Absolute Battery Replacement: passo 2, imagem 2 %32 Dyson V8 Absolute Battery Replacement: passo 2, imagem 3 %32
    • Turn device completely over to view battery pack.
    • Below the bin, use a Phillips #2 screwdriver to remove both screws from the battery pack.
  3. Dyson V8 Absolute Battery Replacement: passo 3, imagem 1 %32 Dyson V8 Absolute Battery Replacement: passo 3, imagem 2 %32 Dyson V8 Absolute Battery Replacement: passo 3, imagem 3 %32
    • Pull the battery pack down and away from the device.
    • Battery pack may fall out.
Conclusão
51 outras pessoas executaram este guia.
Jasvir Dosanjh
Membro desde: 10/25/17
1.680 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team S1-G5, Rose Fall 2017 Membro de UW Tacoma, Team S1-G5, Rose Fall 2017
UWT-ROSE-F17S1G5
Membros da 4
Autoria de 15 guias
13 comentários
Great instructions!!
akcosta60 - Responder
I have replaced the battery and I still got a flashing red light, any ideas
georgewaterson - Responder
I replaced my battery and charged the new one- my vac doesnt work
grooveon.g - Responder
if you have got the switch on max slide other way plug it to charge for 3,4 minuite then try should work. do not put on max as it will not work and you will have to do it all over again
anthony richards - Responder
My v8 animal has a new battery but it doesn't seem to want to charge. The 1st of the 3 battery lights lights up constantly, the 2nd just flashes and the 3rd never lights up no matter how long it's left on charge. The motor will run ok on the lower setting but cut's out almost instantly in the highest setting.
Could the charger be at fault?
Trunker Trubshaw -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 49
Últimos 7 dias: 450
Últimos 30 dias: 2,168
Duração total: 164,848
