Ir para o conteúdo principal
Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement
O que você precisa
  1. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement, Brush Bar: passo 1, imagem 1 %32
    • Press the button to disconnect the vacuum head from the connecting pole.
  2. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: passo 2, imagem 1 %32
    • Turn the end cap counterclockwise using the iFixit Opening Tool.
    • If you do not have an iFixit Opening Tool, a quarter may be used instead.
  3. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: passo 3, imagem 1 %32 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: passo 3, imagem 2 %32 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: passo 3, imagem 3 %32
    • Pull the brush bar out of the housing.
  4. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement, Upper Housing and Brush Bar Housing: passo 4, imagem 1 %32 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement, Upper Housing and Brush Bar Housing: passo 4, imagem 2 %32
    • Turn the padlock key counterclockwise using the iFixit Opening Tool.
  5. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: passo 5, imagem 1 %32
    • Unscrew the three front 1.4 cm torx screws using the T8 Torx screwdriver.
  6. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: passo 6, imagem 1 %32 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: passo 6, imagem 2 %32
    • Remove the upper plate once the padlock is unlocked.
  7. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: passo 7, imagem 1 %32 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: passo 7, imagem 2 %32 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: passo 7, imagem 3 %32
    • Unscrew the top two corner 1.4 cm torx screws using the iFixit T8 Torx screwdriver.
    • Remove axie and roller after the screws are taken out.
  8. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: passo 8, imagem 1 %32
    • Remove the drive assembly from vacuum housing.
    • Red wire connecting the drive assembly to housing.
  9. Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: passo 9, imagem 1 %32 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: passo 9, imagem 2 %32 Dyson V6 Motorhead Upper Housing and Brush Bar Housing Replacement: passo 9, imagem 3 %32
    • Pop off the circular plating to remove the housing from the connection piece.
    • Red wire connects through the upper portion of the housing.
Conclusão
7 outras pessoas executaram este guia.
Addie Hedge
Membro desde: 01/24/17
710 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 22-6, Maness Winter 2017 Membro de Cal Poly, Team 22-6, Maness Winter 2017
CPSU-MANESS-W17S22G6
Membros da 4
Autoria de 5 guias
6 comentários
can the direct drive motor unit be replaced rather than replacing the whole motor head. If so where can the motor be purchased from - I’ve internet searched without success!
Mikey - Responder
I am in the same boat, any luck finding just the direct drive motor ?
jerryd -
You can try ebay.
Joe - Responder
Took mine apart and i was certain it was the motor. Removed the drive belt and the motor turned freely. Discovered that the brush pulley was stiff and jammed. Freed it up with wd40 and worked the pulley until it loosened right up. Placed the belt back and now works perfectly. Maybe try this before presuming the motor is burnt out? Just a thought. Cheers!
Paul Stewart - Responder
I’ve disassembled and see the black wire is broken! Has anyone done this?
lawrence - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 35
Duração total: 14,153
