Introdução
Require battery removal, which is not included due to device not having a battery. Connection tubing will need to be removed before motor replacement.
O que você precisa
Identify the two white components between the vacuum handle and the attached component.
10 outras pessoas executaram este guia.
3Comentários do guia
I am terrible at fixing things and this helped me put my vacuum back together after it fell and the motor detached from the handle. Thank you!!!
