Ir para o conteúdo principal
Dyson Supersonic HD03 Hairdryer Filter Replacement
O que você precisa
  1. Dyson Supersonic HD03 Hairdryer Filter Replacement, Filter: passo 1, imagem 1 %32 Dyson Supersonic HD03 Hairdryer Filter Replacement, Filter: passo 1, imagem 2 %32
    • Unplug the hairdryer to avoid further hazard.
  2. Dyson Supersonic HD03 Hairdryer Filter Replacement: passo 2, imagem 1 %32 Dyson Supersonic HD03 Hairdryer Filter Replacement: passo 2, imagem 2 %32
    • Remove the dirty filter cage by twisting the filter towards the left.
    • The filter cage will be unlocked when the red dot matches the white thin circle.
    • Do not run your hairdryer without a filter cage.
  3. Dyson Supersonic HD03 Hairdryer Filter Replacement: passo 3, imagem 1 %32
    • Soak the filter cage in dish soap and warm water for at least 30 minutes.
    • You can leave the filter in for multiple hours or overnight if it's especially dirty.
    • Use the supplied filter cleaning brush or any other cleaning tool to vigorously scrub the soaked filter cage.
    • Be sure to remove all blockages.
  4. Dyson Supersonic HD03 Hairdryer Filter Replacement: passo 5, imagem 1 %32
    • Rinse and dry your filter cage.
    • Check that the filter cage is clean by holding it up to the light - you should be able to see light through it. If you can't, repeat the previous step.
  5. Dyson Supersonic HD03 Hairdryer Filter Replacement: passo 6, imagem 1 %32 Dyson Supersonic HD03 Hairdryer Filter Replacement: passo 6, imagem 2 %32
    • Insert the filter back into the filter cage and install the filter cage back onto the device.
    • The filter cage will be locked when the red dot matches the white filled circle.
Conclusão
Uma outra pessoa concluiu este guia.
Huan-Che Hsu
Membro desde: 09/18/21
192 Reputação
Autoria de 1 guia
Equipe
Um comentário
My Dyson hair dryer has quitting every 30 seconds - apparently overheating. It was very easy to remove the filter cage and wipe the filter clean. Problem solved!
Jimjar - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 67
Duração total: 4,201
