Ir para o conteúdo principal
Dyson Pure Cool AM11 Remote Control Battery Replacement
O que você precisa
  1. Dyson Pure Cool AM11 Remote Control Battery Replacement, Remote Control Battery: passo 1, imagem 1 %32 Dyson Pure Cool AM11 Remote Control Battery Replacement, Remote Control Battery: passo 1, imagem 2 %32
    • Use a Phillips #1 screwdriver to loosen the screw at the base of the remote.
  2. Dyson Pure Cool AM11 Remote Control Battery Replacement: passo 2, imagem 1 %32
    • The battery tray is spring loaded and should slide out on its own.
  3. Dyson Pure Cool AM11 Remote Control Battery Replacement: passo 3, imagem 1 %32 Dyson Pure Cool AM11 Remote Control Battery Replacement: passo 3, imagem 2 %32
    • The battery should come out with mild pressure applied to the bottom.
    • Insert a new CR2032L coin cell battery.
    • Make sure the new battery is inserted positive side up, there will be a small + symbol on the battery to indicate the positive side.
Conclusão
AidenManchester
Membro desde: 11/01/23
252 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 Membro de UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G7
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 32
Duração total: 592
