Ir para o conteúdo principal
Dyson DC58 Main Body Replacement
O que você precisa
Vídeo de Apresentação
  1. Dyson DC58 Main Body Replacement, Bin: passo 1, imagem 1 %32
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Main Body Replacement: passo 2, imagem 1 %32
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Main Body Replacement: passo 3, imagem 1 %32
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Main Body Replacement: passo 4, imagem 1 %32 Dyson DC58 Main Body Replacement: passo 4, imagem 2 %32
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
  5. Dyson DC58 Main Body Replacement, Main Body: passo 5, imagem 1 %32
    • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
  6. Dyson DC58 Main Body Replacement: passo 6, imagem 1 %32 Dyson DC58 Main Body Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
    • Use tweezers to pinch the two visible white clips together.
    • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
  7. Dyson DC58 Main Body Replacement: passo 7, imagem 1 %32
    • Tilt and pull the main body away from the purple cyclone of the vacuum.
    • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
Conclusão
12 outras pessoas executaram este guia.
Krista St Onge
Membro desde: 09/17/15
2.212 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team 2-4, Bruce Fall 2015 Membro de CSU Fullerton, Team 2-4, Bruce Fall 2015
CSUF-BRUCE-F15S2G4
4 Membros
Autoria de 19 guias
4Comentários do guia
Mine ended up dismantled after it had been dropped. Couldn't get it back together until I read the bit about the tweezers /(pliers) and the white clips. It does not push in with out squeezing them first
Jason - Responder
Has anyone replaced the red release catch?
chrisashton1 - Responder
The white C-ring with clips must be pushed down in order to reassemble device. Takes some time to practice.
Anton Simonov - Responder
I'm trying to figure out how to put spring and plastic pieces back in on the inside of red lever on motor body?? Any help I'd really appreciate ?
t_picano - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 60
Ao todo: 14,018
