Ir para o conteúdo principal
Dyson DC58 Bin Replacement
  1. Dyson DC58 Bin Replacement, Bin: passo 1, imagem 1 %32
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Bin Replacement: passo 2, imagem 1 %32
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Bin Replacement: passo 3, imagem 1 %32
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Bin Replacement: passo 4, imagem 1 %32 Dyson DC58 Bin Replacement: passo 4, imagem 2 %32
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
Conclusão
3 outras pessoas executaram este guia.
Ian Sloan
Membro desde: 09/17/15
161 Reputação
Autoria de 1 guia
Equipe
CSU Fullerton, Team 2-4, Bruce Fall 2015 Membro de CSU Fullerton, Team 2-4, Bruce Fall 2015
CSUF-BRUCE-F15S2G4
Membros da 4
Autoria de 19 guias
2 comentários
The bin is stuck and won’t come off, although I have followed the directions above.
Marcy Altimano - Responder
I think the reassembly instructions should be numbered “Step 5” and printed right below Step 4. They aren’t that easy to see.
Mary Miraglia - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 49
Duração total: 12,852
