Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Check out this guide to learn how to remove the battery pack from the Dyson DC58 vacuum. If your vacuum is not charging due to a damaged or dead battery this guide will show you how to replace it!
O que você precisa
Locate the 10mm screw on the side of the battery pack closest to the purple cyclone of the vacuum
Use the 2.0 Phillips head screwdriver to remove the 10mm screw
59 outras pessoas executaram este guia.
16 comentários
I paid just £30 for a black & decker dust buster 10yrs ago & you tell me you want £60 for a replacement battery pack after 3yrs. Dyson has to do better. Your records don’t show that you agreed to replace the pack while the product was under gaurantee so this battery isn’t even 2yrs old!
Yup we have three stain animals in our house two are just over one year old and the other is a little over two years. None of them hold a charge anymore
Had a dyson V8 Animal a little under two years and already needing a new battery.
Think I will go back to using a corded machine which lasts a lot longer and costs a lot less to buy. Sorry dyson but I’m not impressed.
