Ir para o conteúdo principal
Dyson DC56 Motor Replacement
O que você precisa
  1. Dyson DC56 Motor Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the vacuum is unplugged from charger.
    • Warning: Avoid pressing red trigger because the vacuum will turn on the device and begin suction.
  2. Dyson DC56 Motor Replacement: passo 2, imagem 1 %32
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Motor Replacement: passo 3, imagem 1 %32
    • Separate the device with the purple button.
  4. Dyson DC56 Motor Replacement: passo 4, imagem 1 %32
    • Take out the filter.
  5. Dyson DC56 Motor Replacement: passo 5, imagem 1 %32
    • Locate and remove the 10mm Phillips head screw using a Phillips #1 screw driver.
  6. Dyson DC56 Motor Replacement, Battery screw 2: passo 6, imagem 1 %32
    • Locate and remove #000 25mm phillips screw on the reverse side of the vacuum
  7. Dyson DC56 Motor Replacement: passo 7, imagem 1 %32
    • Pull the battery pack down and away from the main body and remove it from the device.
  8. Dyson DC56 Motor Replacement, Motor: passo 8, imagem 1 %32
    • Take out the 10mm screw using a Phillips #1 screwdriver.
  9. Dyson DC56 Motor Replacement: passo 9, imagem 1 %32
    • Use a spudger to separate the back plate covering the motor.
    • Be careful when trying to remove the motor with a metal spudger. Be sure your battery is removed before trying to fully remove the motor.
  10. Dyson DC56 Motor Replacement: passo 10, imagem 1 %32
    • Use a flat spudger to loosen and remove the motor out of the vacuum.
Conclusão
John Czerkawski
Membro desde: 10/02/17
427 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S10-G1, Thompson Fall 2017 Membro de USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 2,367
