Ir para o conteúdo principal
Dyson DC39 Origin Steering Assembly Replacement
O que você precisa
  1. Dyson DC39 Origin Steering Assembly Replacement, Bin: passo 1, imagem 1 %32 Dyson DC39 Origin Steering Assembly Replacement, Bin: passo 1, imagem 2 %32 Dyson DC39 Origin Steering Assembly Replacement, Bin: passo 1, imagem 3 %32
    • Push down on the gray button located next to the power button to release the bin from the ball housing.
    • Pull the bin away, then up from the ball housing to remove it.
    • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
  2. Dyson DC39 Origin Steering Assembly Replacement, Steering Assembly: passo 2, imagem 1 %32 Dyson DC39 Origin Steering Assembly Replacement, Steering Assembly: passo 2, imagem 2 %32 Dyson DC39 Origin Steering Assembly Replacement, Steering Assembly: passo 2, imagem 3 %32
    • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
    • Remove the four 18.0 mm Torx 15 screws.
  3. Dyson DC39 Origin Steering Assembly Replacement: passo 3, imagem 1 %32 Dyson DC39 Origin Steering Assembly Replacement: passo 3, imagem 2 %32 Dyson DC39 Origin Steering Assembly Replacement: passo 3, imagem 3 %32
    • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
    • Hold the steering assembly base near one of the wheels.
    • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
    • Push up on the steering assembly to remove it completely from the ball housing.
    • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
Conclusão
Uma outra pessoa concluiu este guia.
Luke Matusiak
Membro desde: 04/26/17
479 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S23-G6, Livingston Spring 2017 Membro de Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
Membros da 3
Autoria de 6 guias
Um comentário
Thank you, thank you, thank you!
Robin Hill - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 715
