Ir para o conteúdo principal
Dyson DC39 Origin Pre-filter Replacement
  1. Dyson DC39 Origin Pre-filter Replacement, Bin: passo 1, imagem 1 %32 Dyson DC39 Origin Pre-filter Replacement, Bin: passo 1, imagem 2 %32 Dyson DC39 Origin Pre-filter Replacement, Bin: passo 1, imagem 3 %32
    • Push down on the gray button located next to the power button to release the bin from the ball housing.
    • Pull the bin away, then up from the ball housing to remove it.
    • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
  2. Dyson DC39 Origin Pre-filter Replacement, Pre-filter: passo 2, imagem 1 %32 Dyson DC39 Origin Pre-filter Replacement, Pre-filter: passo 2, imagem 2 %32 Dyson DC39 Origin Pre-filter Replacement, Pre-filter: passo 2, imagem 3 %32
    • Remove the purple pre-filter by pulling it up and out of the bin.
Conclusão
Luke Matusiak
Membro desde: 04/26/17
479 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S23-G6, Livingston Spring 2017 Membro de Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 26
Duração total: 3,926
