Ir para o conteúdo principal
Dyson DC39 Origin Cyclone Filter Replacement
O que você precisa
  1. Dyson DC39 Origin Cyclone Filter Replacement, Bin: passo 1, imagem 1 %32 Dyson DC39 Origin Cyclone Filter Replacement, Bin: passo 1, imagem 2 %32 Dyson DC39 Origin Cyclone Filter Replacement, Bin: passo 1, imagem 3 %32
    • Push down on the gray button located next to the power button to release the bin from the ball housing.
    • Pull the bin away, then up from the ball housing to remove it.
    • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
  2. Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: passo 2, imagem 1 %32 Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: passo 2, imagem 2 %32 Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: passo 2, imagem 3 %32
    • Remove the purple pre-filter by pulling it up and out of the bin.
  3. Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: passo 3, imagem 1 %32 Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: passo 3, imagem 2 %32
    • Push down on the red button, located on top of the bin, to release the bottom section of the bin.
  4. Dyson DC39 Origin Cyclone Filter Replacement: passo 4, imagem 1 %32
    • Push the grey button located in between the parts of the red lever to release the clear, bottom section of the bin.
    • The grey button can only be pressed after the bottom section is open.
  5. Dyson DC39 Origin Cyclone Filter Replacement: passo 5, imagem 1 %32 Dyson DC39 Origin Cyclone Filter Replacement: passo 5, imagem 2 %32 Dyson DC39 Origin Cyclone Filter Replacement: passo 5, imagem 3 %32
    • You should notice several notches around the rim of the filter. Slide the plastic opening tool around the rim to release the notches.
    • After releasing all of the notches, pull the filter away from the orange cyclone assembly to remove it from the bin.
Conclusão
3 outras pessoas executaram este guia.
Sam Nelson
Membro desde: 04/26/17
167 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S23-G6, Livingston Spring 2017 Membro de Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 26
Duração total: 3,441
