Ir para o conteúdo principal
Dyson DC28 Animal Wheel Replacement
O que você precisa
  1. Dyson DC28 Animal Wheel Replacement, Wheel: passo 1, imagem 1 %32
    • Flip the vacuum face down with the wheels facing up.
  2. Dyson DC28 Animal Wheel Replacement: passo 2, imagem 1 %32
    • Start on the right side wheel of the vacuum cleaner
    • Remove the plastic wheel cap by sliding the tip of the metal spudger under the edge of the cap.
    • Gently pry off the plastic cap
  3. Dyson DC28 Animal Wheel Replacement: passo 3, imagem 1 %32 Dyson DC28 Animal Wheel Replacement: passo 3, imagem 2 %32 Dyson DC28 Animal Wheel Replacement: passo 3, imagem 3 %32
    • Identify the e-clip located under the metal axle.
    • The e-clip is very small and may be hard to identify. It is a small metal ring between the metal axle and the plastic wheel.
    • Use the metal spudger to pry off the e-clip.
    • The e-clip is hard to remove and may require extra force.
  4. Dyson DC28 Animal Wheel Replacement: passo 4, imagem 1 %32 Dyson DC28 Animal Wheel Replacement: passo 4, imagem 2 %32
    • Slide off the plastic wheel off of the metal axle
    • Be careful when removing plastic wheel. There is a loose metal washer and black axle piston behind the wheel that can easily fall off.
    • Slide off the metal washer and black axle piston from the metal axle
  5. Dyson DC28 Animal Wheel Replacement: passo 5, imagem 1 %32
    • Remove the metal axle by pulling on the left wheel. This does not take a lot of force and should easily slide out.
    • Repeat steps 2, 3, and 4 to remove the left side wheel from the metal axle.
Conclusão
Zachary Urciuoli
Membro desde: 01/27/17
101 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 21-4, Maness Winter 2017 Membro de Cal Poly, Team 21-4, Maness Winter 2017
CPSU-MANESS-W17S21G4
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 2,987
