Ir para o conteúdo principal
Dyson DC28 Animal Post/Pre Filter Assemblies Replacement
  1. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement, Post/Pre Filter Assemblies: passo 1, imagem 1 %32
    • Find and press firmly on the red button located above the dust chamber.
    • Hold the handle and pull away from the vacuum base when the button releases the dust chamber.
    • Set off to the side.
  2. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: passo 2, imagem 1 %32 Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: passo 2, imagem 2 %32
    • Find and firmly press the purple buttons on each side of the pre filter assembly.
    • When the button releases the filter and its casing, lift straight out of vacuum base.
    • After removing the filter in its casing, hold the case with one hand while gently prying the filter out with your other hand.
  3. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: passo 3, imagem 1 %32 Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: passo 3, imagem 2 %32
    • Find the tab for the post filter cap and pull away from base of vacuum to release the top.
    • When the cap has been swung out of the way, pry the post filter out gently (using same technique as before with pre filter).
Conclusão
3 outras pessoas executaram este guia.
Quentin Klueter
Membro desde: 01/27/17
164 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 21-4, Maness Winter 2017 Membro de Cal Poly, Team 21-4, Maness Winter 2017
CPSU-MANESS-W17S21G4
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 20
Duração total: 1,929
