Ir para o conteúdo principal
Dyson DC28 Animal Air Muscle Assembly Replacement
O que você precisa
  1. Dyson DC28 Animal Air Muscle Assembly Replacement, Sole Plate: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Coin
    $2.99
    Comprar
    • Lay the vacuum on its side to allow for easy access to the bottom of the cleaner head.
    • Unlock the sole plate by using a quarter or other flat tool to turn the three plastic bolts counter-clockwise, as indicated on the sole plate.
    • The plastic fasteners can be damaged when using a metal tool to turn them.
  2. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 2, imagem 1 %32 Dyson DC28 Animal Air Muscle Assembly Replacement: passo 2, imagem 2 %32
    • Gently pull off the sole plate
  3. Dyson DC28 Animal Air Muscle Assembly Replacement, Air Muscle Assembly: passo 3, imagem 1 %32
    • Remove the dust collector using the red button located at the top of the bin
  4. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 4, imagem 1 %32
    • Flip the vacuum over to allow for easy access to bottom.
  5. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 5, imagem 1 %32 Dyson DC28 Animal Air Muscle Assembly Replacement: passo 5, imagem 2 %32 Dyson DC28 Animal Air Muscle Assembly Replacement: passo 5, imagem 3 %32
    • Identify the 6 screws.
    • Remove the six 9mm screws using T15 Torx Screwdriver.
  6. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 6, imagem 1 %32
    • Gently remove the drive cover.
  7. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 7, imagem 1 %32
    • Remove the drive assembly.
  8. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 8, imagem 1 %32 Dyson DC28 Animal Air Muscle Assembly Replacement: passo 8, imagem 2 %32
    • Grab the hose by hard plastic base.
    • Pull firmly to remove it from the holder.
    • If you pull too hard the plastic can be ripped.
  9. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 9, imagem 1 %32 Dyson DC28 Animal Air Muscle Assembly Replacement: passo 9, imagem 2 %32
    • Firmly grab top section of the hose and remove from the holder.
  10. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 10, imagem 1 %32
    • Remove section of the hose from the vacuum.
  11. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 11, imagem 1 %32 Dyson DC28 Animal Air Muscle Assembly Replacement: passo 11, imagem 2 %32
    • Go to the wheel on the right side of the vacuum.
    • Remove the cap of wheel by sliding in a small metal spudger or flat head screwdriver and gently prying up.
  12. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 12, imagem 1 %32 Dyson DC28 Animal Air Muscle Assembly Replacement: passo 12, imagem 2 %32
    Metal Spudger
    $2.99
    Comprar
    • Use the pointed end of a metal spudger to pull off the e-clip.
    • The e-clip is hard to remove and may require some effort to remove.
  13. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 13, imagem 1 %32
    • Pull the wheel off of the axel.
  14. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 14, imagem 1 %32
    • Remove the axel piston from axel.
    • Be careful not to lose the washer on the end of the axel piston.
  15. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 15, imagem 1 %32
    Flush Cutter
    $29.99
    Comprar
    • Use the wire cutters to cut the zip tie holding the tube on.
    • Be careful not to cut the plastic hose.
  16. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 16, imagem 1 %32
    • Gently pry and pull the tube off of the nub.
  17. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 17, imagem 1 %32
    • Use a flat head screwdriver or metal spudger to push the plastic out of the way and remove the air muscle.
    • Be careful not to break the plastic. Bend it just enough to remove the part.
  18. Dyson DC28 Animal Air Muscle Assembly Replacement: passo 18, imagem 1 %32
    • Remove the air muscle from the rest of the vacuum.
Conclusão
4 outras pessoas executaram este guia.
Alec Goodman
Membro desde: 01/25/17
222 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 21-4, Maness Winter 2017 Membro de Cal Poly, Team 21-4, Maness Winter 2017
CPSU-MANESS-W17S21G4
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 51
Duração total: 9,291
