Introdução
This guide will take you through the removal of the of the sole plate and the air muscle assembly. The final goal of this guide is to remove and replace the air muscle assembly.
O que você precisa
Remove the dust collector using the red button located at the top of the bin
Ferramenta utilizada nesse passo:Metal Spudger$2.99
Use the pointed end of a metal spudger to pull off the e-clip.
Ferramenta utilizada nesse passo:Flush Cutter$29.99
Use the wire cutters to cut the zip tie holding the tube on.
4 outras pessoas executaram este guia.
