Ir para o conteúdo principal
Dyson DC14 Power Cord Replacement
O que você precisa
  1. Dyson DC14 Power Cord Replacement, Power Switch: passo 1, imagem 1 %32 Dyson DC14 Power Cord Replacement, Power Switch: passo 1, imagem 2 %32
    • Start with your Dyson DC14 unplugged, standing upright and facing towards you.
    • Remove the canister from the vacuum.
    • Disconnect the telescopic vacuum wand.
    • Remove the two T15 Torx screws securing the switch cover to the vacuum.
  2. Dyson DC14 Power Cord Replacement: passo 2, imagem 1 %32 Dyson DC14 Power Cord Replacement: passo 2, imagem 2 %32
    • Push outward on the two plastic clips that secure the switch cover to the vacuum.
    There are also two screws ( one of which can been seen on the photo and another a few inches below ) that need to be removed BEFORE pushing outward on the plastic tabs.
    martyn.lockhart - Responder
  3. Dyson DC14 Power Cord Replacement: passo 3, imagem 1 %32
    • Remove the switch cover from the vacuum.
    • The purple switch button may separate from the rest of the switch cover.
  4. Dyson DC14 Power Cord Replacement: passo 4, imagem 1 %32
    • Holding them by their white plastic coverings, firmly pull the two wires from the power switch.
    • Be sure to grip the wires from their attached connectors. Pulling directly on the wires could damage your vacuum.
    • The terminals will only fit one way during reassembly. Only one of the wires is long enough to reach the far terminal of the switch.
    I can’t unplug the old starter. It seems stuck. What am I doing wrong?
    Jane Wells - Responder
    I can’t unplug old starter from dyson dc14. Seems stuck. Help please
  5. Dyson DC14 Power Cord Replacement, Power Cord: passo 5, imagem 1 %32
    • Remove the other terminal for the power cord that connects to the terminal below the power switch.
    • Holding them by their connectors, separate the remaining wire of the power cord from the internal power cable.
    Love this repair guid
    Justin DePascale - Responder
Conclusão
16 outras pessoas executaram este guia.
Donald Percivalle
Membro desde: 10/03/12
1.923 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 3-22, Amido Fall 2012 Membro de Cal Poly, Team 3-22, Amido Fall 2012
CPSU-AMIDO-F12S3G22
Membros da 4
Autoria de 8 guias
5 comentários
thanks, Just the basic instructions I needed.
debpet666 - Responder
What a great site! Easy to follow instructions. My part fit perfectly. I booked marked you site and will be back when necessary. Thank y’all
Jerry Chastine - Responder
Definitely helpful
Allen wrench works fine.
No need to buy Torx screwdriver
tacsfs - Responder
I was able to remove the terminals from the power cord but am not sure how to remove the connectors from the wires. I am guessing I need to remove these connectors to get the old power cord and then use the connectors with the new wires.
carrikenney - Responder
Hello, I have been given a Dyson DC 14 and it looks like the plug has been chopped off clean all the way at the very end of the Court. I would like to replace the plug or the entire cord if that's the case. But I am wondering if I do replace the cord and spend that type of money how do I know if it's going to work or not? So is there a way to test the vacuum with my car battery by touching the two cords to the terminals? also which cord is positive and which cord is negative cuz there's a black and a white cord? I have always wanted a Dyson vacuum. It is actually been a dream of mine because I think they're so cool. So now that I have one I want to fix it as inexpensively as possible. Please help thank you so much Brian Higgins
BRIAN HIGGINS - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 54
Duração total: 57,722
