Ir para o conteúdo principal
Dyson Cyclone V10 Absolute Motor Assembly Replacement
O que você precisa
  1. Dyson Cyclone V10 Absolute Motor Assembly Replacement, Motor Assembly: passo 1, imagem 1 %32 Dyson Cyclone V10 Absolute Motor Assembly Replacement, Motor Assembly: passo 1, imagem 2 %32 Dyson Cyclone V10 Absolute Motor Assembly Replacement, Motor Assembly: passo 1, imagem 3 %32
    • Remove the extra parts of the vacuum, including the filter and the bin.
    • Press the red arrow under the bin and pull it out.
    • Remove the filter by turning it counterclockwise.
    • Prior to starting the repair, remove the battery.
  2. Dyson Cyclone V10 Absolute Motor Assembly Replacement: passo 2, imagem 1 %32 Dyson Cyclone V10 Absolute Motor Assembly Replacement: passo 2, imagem 2 %32 Dyson Cyclone V10 Absolute Motor Assembly Replacement: passo 2, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the one 16.5 mm screw on the back of the handle and two 16.5 mm screws under the battery.
    • Pull the battery downward to remove.
    • If you're just replacing the battery, follow the first two steps in reverse order.
  3. Dyson Cyclone V10 Absolute Motor Assembly Replacement: passo 3, imagem 1 %32 Dyson Cyclone V10 Absolute Motor Assembly Replacement: passo 3, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the four 16.5 mm screws on the back of the vacuum.
  4. Dyson Cyclone V10 Absolute Motor Assembly Replacement: passo 4, imagem 1 %32 Dyson Cyclone V10 Absolute Motor Assembly Replacement: passo 4, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the two 16.5 mm screws under the middle of the vacuum, in front of the handle.
  5. Dyson Cyclone V10 Absolute Motor Assembly Replacement: passo 5, imagem 1 %32 Dyson Cyclone V10 Absolute Motor Assembly Replacement: passo 5, imagem 2 %32
    • To separate the body of the vacuum from the motor assembly, gently pull them apart.
Conclusão
3 outras pessoas executaram este guia.
Kuiyao
Membro desde: 09/19/22
243 Reputação
Autoria de 1 guia
Equipe
York University, Team A-6, Morris Fall 2022 Membro de York University, Team A-6, Morris Fall 2022
YORK-MORRIS-F22SAG6
Membros da 3
1 Guia de autoria
2 comentários
Hi I didnt realize u cant vaccum up flour and i vaccumed up quite a bit that spilled. When i went to clean the unit the actual motorhead. After removing the sliding case i stood the motorhead ip and talled the end and all kinds of flour came out the end tube of the motorhead. I kept tapping and more and more flour came out. Is it possible to take apart motorhead or should i take it to repair shop. Please advise
Vicki Benn - Responder
blow it out with an air compressor to get the flour all out...
Jeremy 888ferris - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 65
Últimos 30 dias: 288
Duração total: 4,948
