Ir para o conteúdo principal
Dyson Cinetic Big Ball Animal Upright Hose Replacement
O que você precisa
  1. Dyson Cinetic Big Ball Animal Upright Hose Replacement, Hose: passo 1, imagem 1 %32 Dyson Cinetic Big Ball Animal Upright Hose Replacement, Hose: passo 1, imagem 2 %32
    • Lift off the dust bin from the Dyson.
  2. Dyson Cinetic Big Ball Animal Upright Hose Replacement: passo 2, imagem 1 %32
    • Locate the removable hose on the back of the Dyson.
    • Pull up on the hose in order to remove the top half of the hose.
  3. Dyson Cinetic Big Ball Animal Upright Hose Replacement: passo 3, imagem 1 %32
    • Locate the red tab on the frontside of Dyson.
  4. Dyson Cinetic Big Ball Animal Upright Hose Replacement: passo 4, imagem 1 %32 Dyson Cinetic Big Ball Animal Upright Hose Replacement: passo 4, imagem 2 %32 Dyson Cinetic Big Ball Animal Upright Hose Replacement: passo 4, imagem 3 %32
    • Lift up the red tab with the screwdriver while simultaneously pulling on the back hose.
Conclusão
Karla Sunjara
Membro desde: 01/24/17
891 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S13-G1, Banghart Winter 2017 Membro de Cal Poly, Team S13-G1, Banghart Winter 2017
CPSU-BANGHART-W17S13G1
Membros da 3
Autoria de 10 guias
2 comentários
Following step 4, I tried to “lift” the red tab with my screwdriver. It did not budge. After enlarging the photo, I saw that the tab can be seen from both sides. Therefore, I tried “pushing” the red tab instead of “lifting” it, and it popped right off. “Lifting” and “pushing” are different actions.
vlkea01 - Responder
I've taken the small hose out (in the picture, it is in the center at the bottom of the balls) now I cannot get it back in - at one point I thought I had it snapped back in but it didn't stay - any ideas?
K BS - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 57
Duração total: 11,846
