Ir para o conteúdo principal
Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement
O que você precisa
  1. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement, Brushbar Power Button: passo 1, imagem 1 %32
    • Gently pull up on red handle to separate the hose from the external hose of the Dyson.
  2. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: passo 2, imagem 1 %32 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: passo 2, imagem 2 %32
    • Locate the 18mm four screws on the Dyson above the sticker.
  3. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: passo 3, imagem 1 %32 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: passo 3, imagem 2 %32 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: passo 3, imagem 3 %32
    • Unscrew the four 18mm screws.
  4. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: passo 4, imagem 1 %32 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: passo 4, imagem 2 %32
    • Locate and push the grey button (where the index finger is pointing) while simultaneously pulling up on the handle.
  5. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: passo 5, imagem 1 %32 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: passo 5, imagem 2 %32
    • Pull on the plastic case below the power and brush bar buttons to separate it from the Dyson.
  6. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: passo 6, imagem 1 %32 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: passo 6, imagem 2 %32
    • Slide the buttons out from the case and replace.
Conclusão
Karla Sunjara
Membro desde: 01/24/17
891 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S13-G1, Banghart Winter 2017 Membro de Cal Poly, Team S13-G1, Banghart Winter 2017
CPSU-BANGHART-W17S13G1
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 2,627
