Ir para o conteúdo principal
Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement
O que você precisa
  1. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement, Canister Unlocking Mechanism Spring: passo 1, imagem 1 %32
    • If the top handle does not pop up when trying to remove canister, press the gray button as you gently pull up on the top handle.
  2. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement: passo 2, imagem 1 %32
    • Locate the spring in the small opening between the handle and ball of the vacuum body.
  3. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement: passo 3, imagem 1 %32
    • Pull out the spring by carefully inserting tweezers into the opening.
    • Carefully remove the spring.
Conclusão
Allison Turnbaugh
Membro desde: 01/25/17
213 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 9-5, Banghart Winter 2017 Membro de Cal Poly, Team 9-5, Banghart Winter 2017
CPSU-BANGHART-W17S9G5
Membros da 3
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 2,350
