Ir para o conteúdo principal
Dyson Cinetic Animal Ball Motor Replacement
O que você precisa
  1. Dyson Cinetic Animal Ball Motor Replacement, Release the canister: passo 1, imagem 1 %32
    • Press the gray button to release the canister.
  2. Dyson Cinetic Animal Ball Motor Replacement, Remove the canister: passo 2, imagem 1 %32
    • Remove the canister by lifting it out.
  3. Dyson Cinetic Animal Ball Motor Replacement, Unscrew the base plate: passo 3, imagem 1 %32
    • Find and remove the four 21.5mm screws on the bottom that hold the base plate on using a T15 Torx bit.
  4. Dyson Cinetic Animal Ball Motor Replacement: passo 4, imagem 1 %32
    • Locate and remove the 21mm screws for each wheel on the ball using a T15 Torx bit.
    • Remove the plastic disc.
  5. Dyson Cinetic Animal Ball Motor Replacement, Unscrew the plastic enclosure: passo 5, imagem 1 %32
    • Locate and remove the five 22mm screws on each side of the ball that keep the plastic enclosure together using a T15 Torx bit.
  6. Dyson Cinetic Animal Ball Motor Replacement, Open up the plastic sphere: passo 6, imagem 1 %32
    • Remove the bottom half of the plastic sphere to reveal the motor.
  7. Dyson Cinetic Animal Ball Motor Replacement, Remove the motor: passo 7, imagem 1 %32 Dyson Cinetic Animal Ball Motor Replacement, Remove the motor: passo 7, imagem 2 %32
    • Carefully slide the motor out of its housing in the ball.
    • Cut the two wires near the side of the motor using wire cutters.
    • Install the new motor by splicing in the wires.
    • Watch this video by NJprepper321 on how to splice together wires if you are unsure on how to do this.
    • Make sure to match the wires on the motor with the correct wires in the vacuum.
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 9-5, Banghart Winter 2017 Membro de Cal Poly, Team 9-5, Banghart Winter 2017
CPSU-BANGHART-W17S9G5
Membros da 3
Autoria de 18 guias
4 comentários
Basic but correct only mine has spade connectors on the motor so no need to cut and solder wires. The problem I found was that the main inner filter was blocked, probably by cement dust who I am guilty of! I would like to know if this is available as a spare part? I have cleaned it for now but it really needs changing.
Tim - Responder
This vacuum cleaner is based on the DC52 model. The post motor HEPA filter has the part number 922444-02 and is offered by many spart part vendors in the web. Just google Dyson 922444-02. I have made an instruction on how to replare or clean it.
HowThingsWork -
very good instructions, dismantled perfectly.
Allain Ouellette - Responder
great instructions, dismantled perfectly.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 55
Últimos 30 dias: 246
Duração total: 22,377
