Ir para o conteúdo principal
Dyson Ball Multi Floor Upright Main Filter Replacement
O que você precisa
  1. Dyson Ball Multi Floor Upright Main Filter  Replacement, Main Filter: passo 1, imagem 1 %32 Dyson Ball Multi Floor Upright Main Filter  Replacement, Main Filter: passo 1, imagem 2 %32 Dyson Ball Multi Floor Upright Main Filter  Replacement, Main Filter: passo 1, imagem 3 %32
    • For the main filter, locate the body of the vacuum by looking for the cylinder with the orange top. Use your thumb to press down on the red button towards the back of the orange piece.
    • After pressing down on the red button, the body of the vacuum will easily be removed from the vacuum stand.
  2. Dyson Ball Multi Floor Upright Main Filter  Replacement: passo 2, imagem 1 %32 Dyson Ball Multi Floor Upright Main Filter  Replacement: passo 2, imagem 2 %32 Dyson Ball Multi Floor Upright Main Filter  Replacement: passo 2, imagem 3 %32
    • Once the main body of the vacuum is removed, locate the clear handle on the top of the body. There is a purple label that says "Filter".
    • Lift up the clear handle to reveal the main cylindrical filter. Pull out the purple filter piece to replace.
Conclusão
3 outras pessoas executaram este guia.
Nicole Abraham
Membro desde: 01/26/17
821 Reputação
5 Guias de autoria
Equipe
Cal Poly, Team 21-2, Maness Winter 2017 Membro de Cal Poly, Team 21-2, Maness Winter 2017
CPSU-MANESS-W17S21G2
4 Membros
10 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 82
Duração total: 2,862
