Ir para o conteúdo principal
Dyson Ball Animal Power Button Replacement
O que você precisa
  1. Dyson Ball Animal Power Button Replacement, Power Button: passo 1, imagem 1 %32 Dyson Ball Animal Power Button Replacement, Power Button: passo 1, imagem 2 %32
    • Turn off and unplug the vacuum
  2. Dyson Ball Animal Power Button Replacement: passo 2, imagem 1 %32
    • Press the red release button and pull the canister up and away.
  3. Dyson Ball Animal Power Button Replacement: passo 3, imagem 1 %32 Dyson Ball Animal Power Button Replacement: passo 3, imagem 2 %32
    • Locate the red dial at the back of the wand and turn counterclockwise to detach the wand.
  4. Dyson Ball Animal Power Button Replacement: passo 4, imagem 1 %32 Dyson Ball Animal Power Button Replacement: passo 4, imagem 2 %32
    • Remove the four 15mm screws behind the power button using a Torx T15 screwdriver.
  5. Dyson Ball Animal Power Button Replacement: passo 5, imagem 1 %32 Dyson Ball Animal Power Button Replacement: passo 5, imagem 2 %32 Dyson Ball Animal Power Button Replacement: passo 5, imagem 3 %32
    • Use a spudger to push the two clamp tabs behind the power button towards the middle of the vacuum.
  6. Dyson Ball Animal Power Button Replacement: passo 6, imagem 1 %32 Dyson Ball Animal Power Button Replacement: passo 6, imagem 2 %32
    • Detach the power box case from the body of the Dyson after both clamps have been pushed out.
    • Upon removal of this case, you will be able to see a red circular power button.
  7. Dyson Ball Animal Power Button Replacement: passo 7, imagem 1 %32 Dyson Ball Animal Power Button Replacement: passo 7, imagem 2 %32
    • Gently pull the power button out of its slot as shown.
    • Detach the power button box from the two wires connecting it, and replace the faulty power button box with a functional one. The power button is the first black one.
Conclusão
4 outras pessoas executaram este guia.
Hank Wai
Membro desde: 05/07/17
166 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S15-G5, Banghart Spring 2017 Membro de Cal Poly, Team S15-G5, Banghart Spring 2017
CPSU-BANGHART-S17S15G5
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 54
Duração total: 6,829
