Ir para o conteúdo principal
Dynex DX-WBRDVD1 WiFi Antenna Replacement
O que você precisa
  1. Dynex DX-WBRDVD1 WiFi Antenna Replacement, Top Cover: passo 1, imagem 1 %32 Dynex DX-WBRDVD1 WiFi Antenna Replacement, Top Cover: passo 1, imagem 2 %32
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 WiFi Antenna Replacement: passo 2, imagem 1 %32
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 WiFi Antenna Replacement: passo 3, imagem 1 %32
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 WiFi Antenna Replacement, WiFi Antenna: passo 4, imagem 1 %32 Dynex DX-WBRDVD1 WiFi Antenna Replacement, WiFi Antenna: passo 4, imagem 2 %32 Dynex DX-WBRDVD1 WiFi Antenna Replacement, WiFi Antenna: passo 4, imagem 3 %32
    • Use the metal spudger to remove the white clip from the antenna by prying the clip away from the antenna.
    • Use a pointed tool and press down on the indents on both sides of the clip to loosen.
  5. Dynex DX-WBRDVD1 WiFi Antenna Replacement: passo 5, imagem 1 %32
    • Remove the two 7mm screws from both sides of the antenna.
  6. Dynex DX-WBRDVD1 WiFi Antenna Replacement: passo 6, imagem 1 %32 Dynex DX-WBRDVD1 WiFi Antenna Replacement: passo 6, imagem 2 %32
    • Slide the antenna inwards and gently remove.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 280
