Introdução
This is the guide to crack into your device, almost every repair guide will need this completed first before being able to tear into the hardware below.
  1. Use a Phillips #1 screwdriver to remove the four 5mm screws that connect the black outer shell to the silver back of the device. Use a Phillips #1 screwdriver to remove the four 5mm screws that connect the black outer shell to the silver back of the device.
    • Use a Phillips #1 screwdriver to remove the four 5mm screws that connect the black outer shell to the silver back of the device.
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  3. Use a Phillips #1 screwdriver to remove the two 5mm screws on the left and right side panels.
    • Use a Phillips #1 screwdriver to remove the two 5mm screws on the left and right side panels.
      • There is one screw on each side that secures the cover to the body of the device.
  4. Lift the black cover to a 45 degree angle from the rear of the device and pull away from the device.
    • Lift the black cover to a 45 degree angle from the rear of the device and pull away from the device.
    • Check that the power cord is not preventing the device from opening or closing.
Conclusão
Uma outra pessoa concluiu este guia.
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 40
