Ir para o conteúdo principal
Dynex DX-WBRDVD1 Optical Drive Replacement
O que você precisa
  1. Dynex DX-WBRDVD1 Optical Drive Replacement, Top Cover: passo 1, imagem 1 %32 Dynex DX-WBRDVD1 Optical Drive Replacement, Top Cover: passo 1, imagem 2 %32
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Optical Drive Replacement: passo 2, imagem 1 %32
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Optical Drive Replacement: passo 3, imagem 1 %32
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Optical Drive Replacement, Optical Drive: passo 4, imagem 1 %32 Dynex DX-WBRDVD1 Optical Drive Replacement, Optical Drive: passo 4, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the two screws that secure the Optical Drive.
  5. Dynex DX-WBRDVD1 Optical Drive Replacement: passo 5, imagem 1 %32 Dynex DX-WBRDVD1 Optical Drive Replacement: passo 5, imagem 2 %32
    • Detach the tape wires from the motherboard and power board.
  6. Dynex DX-WBRDVD1 Optical Drive Replacement: passo 6, imagem 1 %32 Dynex DX-WBRDVD1 Optical Drive Replacement: passo 6, imagem 2 %32
    • Lift the disc drive up to a 45 degree angle and pull back out of the device shell
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 412
