Introdução
The discdrive is found next to the motherboard and power board inside the device. This guide will take you through the steps of removing the discdrive for replacement.
O que você precisa
Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
Use a Phillips #1 screwdriver to remove the two screws that secure the Optical Drive.
