Ir para o conteúdo principal
Dynex DX-WBRDVD1 Cleaning The Optical Lens
O que você precisa
  1. Dynex DX-WBRDVD1 Cleaning The Optical Lens, Top Cover: passo 1, imagem 1 %32 Dynex DX-WBRDVD1 Cleaning The Optical Lens, Top Cover: passo 1, imagem 2 %32
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Cleaning The Optical Lens: passo 2, imagem 1 %32
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Cleaning The Optical Lens: passo 3, imagem 1 %32
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Cleaning The Optical Lens, Dynex DX-WBRDVD1 Cleaning The Optical Lens: passo 4, imagem 1 %32 Dynex DX-WBRDVD1 Cleaning The Optical Lens, Dynex DX-WBRDVD1 Cleaning The Optical Lens: passo 4, imagem 2 %32
    • To access the optical lens, pull back the optical drive as shown in the pictures located on the two metal rails.
  5. Dynex DX-WBRDVD1 Cleaning The Optical Lens: passo 5, imagem 1 %32 Dynex DX-WBRDVD1 Cleaning The Optical Lens: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Microfiber Cleaning Cloths
    $3.99
    Comprar
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 590
