Introdução
Cleaning your optical drive is standard maintenance especially if your movies wont play. Here is how you get to it and clean it properly.
O que você precisa
Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
To access the optical lens, pull back the optical drive as shown in the pictures located on the two metal rails.
3 outras pessoas executaram este guia.
